Eliminating Custom Door Panel Outline
Dave Jochum
Is it possible to eliminate the door panel outline that apparently is created by default with a custom door? I've created an arch-topped iron gate, so the rectangular outline is not appropriate. I also want the opening lines referencing the actual gate edges, not the outlining rectangle. (Ignore the door showing behind the gate.)
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
1 REPLY 1
Dave Jochum
I've found you can set the FRAME & LEAF OUTLINE PENS in the DOOR SETTING & OPENING - MODEL ATTRIBUTES TO all white (which covers and hides the sharing linework which should not be hidden), but one cannot choose TRANSPARENT. I also cannot find any way to alter the opening line.
Dave Jochum
