2006-03-10 05:35 PM
2006-03-11 12:41 PM
2006-03-11 12:53 PM
2006-03-13 10:08 AM
FPRISM_ endMatl, endMatl, endMatl, endMatl,
5, offsetDist1, 45,offsetDist1,
0, 0, 15,
0, ZZYZX, 15,
-B, ZZYZX, 15,
-B, 0, 15,
0, 0, -1
2006-03-13 10:51 AM
shaun wrote:No, status code value -1 doesn't close main prism contours, it is used for holes!
The status code to close the prism should be "-1"
GDL wrote:
si=-1 is used to define holes directly into the prism. It marks the end of the contour and the beginning of a hole inside of the contour. It is also used to indicate the end of one hole's contour and the beginning of another. Coordinates before that value must be identical to the coordinates of the first point of the contour/hole. If you have used the -1 mask value, the last mask value in the parameter list must be -1, marking the end of the last hole.
2006-03-13 11:00 AM
2006-03-13 12:02 PM
Vitruvius wrote:You found the bug.
You have assigned Offsetdist1 to both thickness & hill_height but hill_height < thickness. Try reducing the hill_height and your edge should reappear.
Cheers
2006-03-13 01:48 PM
Z.Bauer wrote:The use of "-1" is correct, I think.shaun wrote:No, status code value -1 doesn't close main prism contours, it is used for holes!
See below.
2006-03-13 02:57 PM
laszlonagy wrote:Is using of "-1", in context of this topic, really works by you (I'm not meaning that it can be used without holes)? Beacause by me no difference!
I mean, it might be different from what the manual says, but it still works.
Still, the missing edge could be a bug.
2006-03-13 03:06 PM
Z.Bauer wrote:It seems like -1 would be the correct syntax, but 16 yields a correct result more often than -1 did (since with each Rebuild, that last edge seems to disappear or reappear!)laszlonagy wrote:Is using of "-1", in context of this topic, really works by you (I'm not meaning that it can be used without holes)? Beacause by me no difference!
