Read more
Fire sprinklers?
In the AC 11 library we have a smoke/heat/smoke&heat detector but I can't find a sprinkler.
Actually I can't find a sprinkler anywhere.
7 REPLIES 7
Djordje
Ace
Not too hard to make and post on the Depository? I could swear that I have seen it somewhere ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
What does it look like? Is it 3D or just a symbol?
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Petros Ioannou
I'm not quite sure but wasn't there a sprinkler in the old roof extras?
That one with the ceiling lights, detectors etc.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
There is one in the DuctWork HVAC Lib.
DuctWork 11 or we are still dreaming?
TomWaltz
I hate to say "I told you".....
Tom Waltz
If you have Ductwork for AC 09 installed, then, when you open a pln file from AC 09 in AC 11 and load Ductwork lib from AC09 folder through LIb manager in AC11, ..., you have a message of missing addon (which is true) but all Ductwork objects are visible but not functional. So, then you can input object, like sprinkler, and use it in AC11.
