Read more
Forklift
Djordje
Ace
jdk wrote:
I do not like fork lifts...
Speaking of those ...
Does anyone know of a GDL one?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Hello Djordje,
I do not know if you found it ever since
I just find this web page but it is not free unfortunately
http://www.simbirsoft.com/portfolio/3d_modeling/
regards
Jean-Luc
Hmooslechner
http://sketchup.google.com/3dwarehouse/search?q=Gabelstapler&styp=m&scoring=t&btnG=Suchen
You can import this in Archcad. in V16 - You need the Plugin for Google sketchup - download and install it - then You get a new menue within Archicad to import this things.
But there are som restrictions - If You import from Google sketchup - it will make GDLs with so much 3Dfaces You wouldnt be able to count..- which slows down Archicad.
NCornia
Thank you for updating this post!
And to clarify, this functionality is built into AC17 and above. Integrated Connections with Google Earth, Sketchup Get the add-ons for older versions: http://www.archicadwiki.com/SketchUp
To cleanup triangulation from imported objects see this article: http://www.archicadwiki.com/RemoveTriangulationFromImportedObjects But Hmooslechner is correct, excessive polygons can still slow down your file. You should choose efficiently made models to balance good looks and high performance.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
