Formatting A Parameter Script to include a Single Quote 1&qu
I am writing a GDL object that will have a parameter script for common text string choices from a pull down.
i.e.
!!MAIN TEXT
values "MainText" "2x6", "2x8", "2x10", "2x12", "14 TJI 560", custom
The question is how to actually include a single quote in the text string without confusing the syntax of the code?
It would be preferable for the output to be 2"x6" rather than 2x6.
Thanks,
JFA
James Murray
Mentor
jfa_ra wrote:
i.e.
!!MAIN TEXT
Use a different kind of quotation mark; the single (apostrophe) and the little retrograde accent mark (`) will both work.
VALUES 'MainText' '2"x6"', '2"x8"', ...
A bit OT, I would find 2"x8" to be potentially confusing since it should be a nominal dimension. We wouldn't use the inch sign unless it was a true dim. But you should stick with what you and your contractors are accustomed to.
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Cool! Thank you. That was easy.
jfa
