Horizontal Railing Spacing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-01-30 03:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 04:50 PM
If you activate the Balusters page of the Dialog, then on the right side, in the Baluster Pattern Settings panel you can choose the "Fixed Pattern Length" option for pattern distribution. Then in the Baluster Settings panel you can set the distance between the Balusters in the "Distance From Previous" field.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 05:29 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-30 05:46 PM - edited 2022-02-18 05:25 PM
Yes, OK, so I did misunderstand what "horizontal railing spacing" means.
No, you cannot set a fix distance between horizontal Rails.
What I would do is I would use the "Profiled Rail 21" Rail GDL Object, which can use Profiles created in the Profile Manager.
Then in the Profile Manager I would draw the number of Rail profiles at the desired spacing and use that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-15 03:22 PM
Surely there should be the option of horizontal balusters that behave the same as the vertical balusters, the current workflow is very inefficient.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-20 09:38 PM
ponaelius wrote:Can only agree this is a major oversight. I've been messing for the last couple of hours thinking I must be missing something obvious only to come and read this.
I'd hoped this was not the case but I came to the same solution as you Laszlo.
The 'balusters' options support making whole panels by specifying size and spacing. It seems such a logical thing to have the same option available for the rails?
Even the old fence object made this really easy...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-22 03:07 PM
On the other hand railings like these are forbidden basically everywhere (since childs would be motivated to step on them like a ladder).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-22 06:37 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-22 10:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-22 11:01 PM
