Hotlink: not scaling / panning with model
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-07-19
05:15 PM
‎2023-05-23
04:03 PM
Rubia Torres
All are plan views.
The circle in the middle of the screen is my entire model.
The objects in the top left corner appeared and I don't know what it is nor how to delete it.
When I pan the drawing, my model moves but the objects in the top left stays stationary.
The same when I zoom: my model moves but the objects are not affected by the zoom.
And I cant seem to zoom enough to make my model visible, and I cant zoom onto the rogue objects.
When I change the scale, the object do seem to scale with the drawing, but I still cant seem to do anything with them.
When I open my layout and open source view, it takes me back to the view with the objects.
These objects are visible in all my plans (both project map and view map) making it impossible to do any work.
Any advice would be really appreciated.
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 05:29 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 05:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 05:51 PM
It seems it is related to a hotlink.
I removed all the hotlinks, and the file showed correctly.
I then reloaded the one hotlink and the "rogue objects" show again.
But neither zoom nor pan has any effect on the rogue objects.....
But thank you for the help, with the hotlinks removed I can continue working, but I will have to re-hotlink them eventually....
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 06:12 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 03:20 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 11:14 AM
Thank you very much for the report and I am very sorry about the issue!
As Ling suggested, in the hotlink module, please try to make all layers visible and try to zoom with
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 03:19 PM
Perhaps good to mention that I upgraded to Archicad25 late last week and only noticed the issue early this week.
All the models and hotlinks worked fine in Archicad24, so I back-saved the models to Archicad24 and everything seems to work fine now.
I have contacted our supplier of Archicad and I've sent all the files to Graphisoft.
In the meanwhile, we will continue in Archicad24 as the hotlinks seem to work in this version.
Windows 10 Pro
