How to create a louver + window object
fowebe
Hello! Newbie here
I'm wondering if I could combine a louver and (casement) window and make it parametric? No idea on how to model objects in ArchiCAD either
Many thanks!!
Phoebe
_________________
Phoebe Lim / Architecture Student
AC23 • Windows 10 3200MHz 8-core | 16 gb RAM •
fowebe wrote:
Hello! Newbie here
Many thanks!!
Not without knowing a bit of GDL scripting.
Your best bet is to 'gang' the windows together - the default GS windows have ganging options.
Ganging allows you to remove the trim between the frames.
Or depending on what you need to achieve you may be able to simply place the windows next to each other.
They will still all be separate windows but you can group them.
Otherwise the next best option would be to create a custom window - but this will not be parametric.
You will need to create one for each different size and configuration.
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/elements-of-the-vir...
The most useful option, but the hardest to achieve, will be to script the window in GDL.
It may be a case of just 'CALL'ing the separate windows into the correct positions.
This way you can make them all parametric - but you need to know what you are doing.
Versions 6.5 to 26
Hero
Depending on how accurate you need it to be, couldn't you create something similar with a Vertical Multisash Window. Vent sash, top hung, side hung, vent sash.
Win10 | R5 2600 | 16GB | GTX1660
fowebe
Thanks for your help guys!! Appreciate it
I made it as separate window openings and grouped them
Phoebe
_________________
