How to design L shape ramp
Hello ,
I have 2 ramp in my project. One is straight and another is L shaped. I have already designed the straight ramp using object named 'ramp 23'. (See the fig)
But I am can't design the L shape ramp. Are there any other object to draw this?
18 REPLIES 18
Dontknow
Use the mesh tool and elevate the corner points with 'Elevate mesh point' in the pet palette.
Make a surface override to set the right material.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
I know how to draw a slope or ramp using mesh.
I am not interested in using morph or mash.
Are there any other solutions.
Purpose made ramp objects?
Or roofs - but they won't have a flat base.
Or with the stair tool.
https://helpcenter.graphisoft.com/knowledgebase/75566/
Dear Barry
Thanks for sharing this beautiful Guide. We followed the instruction carefully ( See Fig 1 to 7) but still having difficulties.
Which values should I put/should I choose in my stair value. (See Fig 8 & 9)
We are trying to create a ramp without landing but an l shape turn (see fig 11)
You already have done a lot. We are really grateful for that. It would be really helpful if you can take little more time to guide us to learn this technique.
Hmooslechner
Sorry - i put my solutions into the wrong task:
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=70355&sid=a735f44fba2d7490a9cd0c2db2194088
I am not exactly sure.
I have never actually done this myself - I just remember reading it.
I just had a quick try and I could get a ramp but with slightly different settings.
Profile origin is top left.
Stringer in stair is set to left (not right).
But this adds the stringer outside the stair - but that seems to make the best ramp.
I will see if I can find more time to play with it later tonight after work.
I will see if I can get the ramp to sit under the stair - which is really what you want to happen.
No that seems to be the best I can get.
The stringer has to be on the outside otherwise it doesn't trim properly.
It is still a little flat topped
I tried a beam structure but that is very flat topped and can only be moved in half the width of the stair.
The only other success I had was to just create a standard monolithic stair.
I made the throat quite thick and set the bottom end connection to vertical.
Then drag a copy of it self vertically and then do a Solid Element Operation to cut the top one from the lower one.
Achille Pavlidis
Hi, I'm having a similar problem. Just trying to create an L shaped ramp with a 5% slope between two landings. Tried everything, but cannot get it right. See attached images. It always seems to have some random riser or landing.
Any suggestions?
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Does it has to be a stair?
You could try a mesh to define node elevations then use Mesh to Roof Goodie to create roofs. Finally convert the roofs to morphs.
HTH.
