IFC properties to zonestamp (request)
rozky
Hi
I'm trying to modify zone stamp to automate ApartmentID - stApartmentID = IFCproperties(zome(ID))
I looked at http://gdl.graphisoft.com/reference-guide/request-options
but my gdl skill is not so good and i cant figure it out so I want to ask for help please.
Peter
Ryzen Threadripper 1950X - 64GB RAM; NVidia GTX 1080Ti ; Windows 10 64bit; AC10-AC23 (64bit)
8 REPLIES 8
Set the mapping instead IMHO
Piotr
alemanda
Yes Rozky... you have to map your IFC property to get the combined name.
Unfortunately you can combine texts but you cannot make mathematics yet ... we hope in the future
AC 19 and AC21 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
rozky
Thank you for reply.
Yes I did it(IFC mapping) problem was to show it in zone stamp.
I finally got it out. I do not know it is clever solution but it work.
This link was very helpful http://gdl.graphisoft.com/tips-and-tricks/display-properties-with-labels
Thank you all
alemanda
you have to use labels ... and not the zonestamp
Win 10 Pro 64bit
www.almadw.it
rozky
I modify zonestamp. Now it works.
Peter
Alemanda: Such requests work in labels, markers and zone stamps without problems.
(I recently modified 21 DW marker to get the fire rating not from object parameter but the properties)
Best Regards,
Piotr
alemanda
Yes ... Through GDL you can request that IFC data, I know.
Win 10 Pro 64bit
www.almadw.it
The lack of proper documentation with examples is GDL's bottleneck...
getting better: some useful examples show on gdl.graphisoft.com
but regarding this topic the documentation is misleading - saying that it works in labels only...(should be either label-like objects or specifying the 3 possibilities).
Best Regards,
Piotr
