ISSUE: UI Dialogue User Interfase
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-09-26 11:50 PM
I would like to point at two thinks:
1. In ArchiCAD GDL manual, it does say anything about how it can become a problematic issue working with .PNG or .Tif files type directly on the user interface dialogue box (
2. I think you should work of this issue
Best regards,
Nader
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-27 11:01 PM
There is an error in my photo-editing program that is generating my errors.
Sorry, my bad
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-28 02:07 AM
1. In the manual you should mention that pics used in the dialogue box should be of 96 ppi, while those used in buttons is of 72 ppi.
2. I use Adobe products to generate the graphical contents (Photoshop, Illustrator, & Bridge), and it happens that if I generate pics with transparencies (either as .tif or .png) for the dialogue box, those images will not appear with the desired transparency, I believe that it have to do with the settings saving those pics from vector graphics.
Example of an ArchiCAD original pic with transparency in Adobe Bridge
Example of a pic with transparency in Adobe Bridge made by me
as you can observe ArchiCAD original graphics have a different way to represent transparencies.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-28 01:28 PM
When You analyze the original tiffs - they contain 100%, 150%, 200%, 300%.
The library tools can create such tiffs out of svg files, however... the manual is lacking the straightforward info how to do it...
If You are on the PC: make a bat file containng this: "C:\Program Files\GRAPHISOFT\LibDev Toolkit 22 (3013)\Tool\WIN\LP_XMLConverter" convertlibrary -excludesvg %1 %1_tifAnd than make it a right click option on the folder. You can use the Ultimate Windows Context Menu Customizer app, or modify registry manually
(sidnote correct the path of the lib devkit)
Having it done You can right click on the folder containing svg files, and after clicking on the above option, you will get another folder having the same name as the clicked one extended by "_tif".
Best Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-28 09:33 PM
I have found out a thread in a graphical designers forum that commented my issues, and it happens that the transparencies in original ArchiCAD's tiff are defined as 0%, while Adobe Packages saves those transparent areas as NoData.
I will try your way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-09-28 10:40 PM
The only problem with some transparency issues is when the file is scaled wrong - ie. until I have found an easy way to create those multipage tiffs I did overscaled pngs - but in some cases it caused a blurry lines unless the scaling was 100%
Piotr
BTW. Try avoiding use of svg's created out of bitmaps - the best results will be with pure vector content
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-01 01:51 PM
Can you give me an insight for the correct way to scale them ? Just in case that I'm doing it wrong?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-01 03:33 PM
When I have to deal with the bitmap file created manually - I use export persona in Affinity Designer and create setup of exporting set of tiff files with transparency on 100%, 150%, 200% and 300%...
Then I use imagemagic to put them together...
Same MO:
I created a right click option to put together tiffs inside the folder - so I get the file with the name of this folder
the below line is put to bat file and this bat file is set as a right click command on folder.
"C:\Program Files\ImageMagick-7.0.8-Q16\magick.exe" convert %1\*.tiff %1.tiff
of course the image magic folder can change...
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-03 01:13 AM
@Pitor Dobrowolski, you're right, about the multipage tiffs.
How the hell did Graphisoft forgot to tell it's users about that!!!!! NO why many users were banging their heads
And thanks alot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-10-03 01:33 AM
You can check it here:
