2023-04-11 08:33 AM
Spacing and number are possible.
You can also check the number in the schedule.
2023-04-11 09:06 AM
An array for what exactly?
Do you want to show/adjust the spacing in the schedule?
That is not possible, unless all of those beams are actually one object with a parameter that controls the spacing.
If they are separate beams, then there is nothing you can do to schedule the spacing.
2023-04-11 09:28 AM
If you know your total length, you could use the Edit => Distribute function. Then if you group the objects, you could then move the end ones to modify to total length and redistribute.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
