I have created several objects in AC10, also tried in 8.1 and they will not load. If I try to load them with the dialog box they are "greyed" out and cannot be selected. The first two I made loaded fine, I then tried to rotate one and save it in a different angle from the 3D window and since then no objects created can be loaded.
Any clues?? I'm completely baffled.....
