Opening in wall mising 2 lines
Hello!
Ive inserted an empty opening into the wall by if you look at the picture you can see that the 2 lines at the sieds off the wall are missing. Can they be somehow visible.
Also is it possible that my wall opening size is +2 cm biger then my window size? Can this be made automatic so I dont need to override the dimension marker for every window?
Thank you people 🙂
ok Ive find the solution for the first qestion, but can you help me with second one.
Thanx
vfrontiers
Thanx
Was the answer to the first one.... Ganging? Connection on Left / Right?
No. 2 is likely either OVERSIZE or the Rough Opening vs Unit Size...
Duane
Visual Frontiers
AC25 :|: AC26 :|: Enscape3.4:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
Helo vfrontiers!
I tried what you said, but now if I use the automatic dimensioning tool, the value that it show coressponds to the window size not to the openng size. (pic)
Can this be done couse I dont want to dimension everything manualy 😞
