Partitions
just switched to Archicad11 and noticed that there is no bathroom partition walls in the object library like 10 had. I was wondering if there was a way to get them. I didn't see any in the free depository.
thanks
kirby
5 REPLIES 5
There should not be a problem duplicating the AC 10 object file,
renaming it and putting it in a custom objects folder and
adding this folder to the loaded libraries in an AC 11 project.
If there is a problem there should be no dire consequences
except the object is not useable in AC 11.
Peter Devlin
Thanks for the help
kirby
Erika Epstein
There is also an AC10 subset library to be loaded with AC11 at
http://tr.graphisoftus.com/
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
Huh -- I have the `Restroom Partition 11` in my ArchiCAD Library 11 (USA)...
AC26 US (5002) on Mac OS Ventura 13.5
Do a 'find library part' with the word 'partition' on the US library and you'll find:
Object Library 11 > 10 Specialties 11 > Partitions 11 > Restroom Partition 11
which has a graphic interface under the "Restroom Partition Settings" panel as seen in the screenshot below.
Is this what you needed?
One of the forum moderators
