Question about SYMB_MIRRORED ?
Nader Belal
Mentor
Hi there,
SYMB_MIRRORED is an Archicad Global Variable to indicate if the object have been mirrored.
My question, how to extract the mirror operation value ??
ie: was it mirrored on the X-axis, Y-axis, arbitrary axis .
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
7 REPLIES 7
runxel
Ace
You have SYMB_MIRRORED and SYMB_ROTANGLE.
If the rotation angle is 180° (and symb_mirrored is set of course) you can tell it was mirrored a long the x-axis. If no rotation angle is set the mirror axis was the y-axis.
But I don't think you can tell what the very last operation was, since there is no way to compare between states in GDL.
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Nader Belal
Mentor
That's why I think there should be a Global variable that can tell us the values
I think you will find the object is always mirrored about the Y-axis when you look at it in the symbol 2D view of the script editor.
i.e. positive X becomes negative X.
Rotation of the object placed instance does not affect the mirroring, as it will always mirror along the original Y-axis of the object.
Versions 6.5 to 25
Nader Belal
Mentor
@Barry Kelly
Is there a way to make the object quasi (self-aware) of the mirrored value ?
Like what happens with rotation and XY position ?
I”m not quite sure what you mean.
An object either is or isn’t mirrored.
You can always force an object not to mirror.
If it is mirrored you just MUL2 -1,1 in 2D and MULx -1 in 3D.
Versions 6.5 to 25
Nader Belal
Mentor
Example,
What if the the correct form to prevent mirror is mul2 1, -1?
It is always mirrored in the x-axis (about the y-axis) so you only need to MUL the x value at the beginning of your script.
Versions 6.5 to 25
