SYMB_ROTANGLE query
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-07-13 04:15 PM
2018-07-13
04:15 PM
I was wondering if it was possible to lock down the ability to rotate an object from within it?
(So it can't be rotated when placed)
Thanks!
ArchiCAD 27
Windows 10
Windows 10
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 04:28 PM
2018-07-13
04:28 PM
I use a 'trick' to stop symbols from being displayed as mirrored:
You could do the same with symb_rotangle, I would say.
I don't think rotation is a lockable parameter as A, B and ZZYZX are.
if symb_mirrored then mul2 -1,1That is part of the 2D script, since it is just a 2D object. However, the object itself will still be mirrored.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 04:44 PM
2018-07-13
04:44 PM
Erwin wrote:I understand I can just do ROT2 -symb_rotangle but I was just curious if there was a way of either setting it to always be 0 or lock it or hide it but from what I can tell, you can't do any unfortunately
I use a 'trick' to stop symbols from being displayed as mirrored:if symb_mirrored then mul2 -1,1That is part of the 2D script, since it is just a 2D object. However, the object itself will still be mirrored.
ArchiCAD 27
Windows 10
Windows 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-16 08:34 AM
2018-07-16
08:34 AM
You can lock the object itself after you place it, but I don't think that is what you are after.
The mirror and rotate 'trick' I find mostly useful for 2D objects that should not be mirrorerd etc when used with hotlinked modules.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-16 09:32 AM
2018-07-16
09:32 AM
SYMB_MIRROR and SYMB_ROTANGLE aren't actually parameters like A, B, ZZYZX, etc.
Therefore you can't LOCK or HIDE them in an object script.
The best you can do is to un-mirror or un-rotate as you have discovered.
