2022-05-16
12:52 PM
2023-05-24
09:42 AM
Rubia Torres
Dear Community,
Many of you took part in our recent survey on “Detail Levels of doors and windows on a single drawing”:
Thank you for your contributions and valuable insights!
Your answers highlighted several use cases for varying detail levels on a single drawing: for example, Renovation, Refurbishment, and Security drawings.
We would like to investigate these use cases further. If you have plans and documentation that show such use cases (that is, doors and windows with different detail levels in a single drawing – e.g. existing windows are simple, and new windows are detailed), and if you are happy to share them with us, please leave a comment, and we will contact you directly. Thank you!
Solved! Go to Solution.
2022-05-16 01:10 PM
I am happy to share examples and have already discussed with Gergely. I will collate some and send them across.
2022-05-16 01:59 PM
Thank You !
2022-05-16 02:01 PM - edited 2022-05-16 02:33 PM
For analysis (sun etc) I'd like the glass as one mesh and the frame as one. Like the MVO schematic but with the frame.
2022-05-16 03:23 PM
The link is not working
2022-05-16 03:28 PM
Hey Filip! Thanks for the heads up! I've changed the link, hope it works now.
2022-11-05 08:54 AM
Hi Jeno,
Yes, would be fantastic extend MVO options about Detail in different Renovation status, not only for Doors and Windows (also Library part, Stairs...)
and please, add in MVO also behavior for Grid Element - show only Grid line, Grid with Naming without Marker Shape, show complet
Thanks
Marek
2022-12-05 09:17 AM
Thank You Mats!
2022-12-05 09:19 AM
Hi Maro! Thank You for the reply!
2022-12-05 09:20 AM - edited 2022-12-05 09:21 AM
Thank You Everyone for sharing plans and cases, and participating in our research to make this area in Archicad better!
