2003-12-15 06:00 PM
2003-12-17 03:32 AM
2003-12-17 04:35 AM
Karl wrote:... and the window itself?
Can you post an elevation view of your window?
2003-12-17 10:50 AM
2003-12-17 10:53 AM
2003-12-17 11:04 AM
2003-12-17 11:17 AM
2003-12-17 01:02 PM
Thomas wrote:That is the answer to your question. When you make the window that way, the plan hole size equals the width of ALL the elements that make the window - including the trimmings. So the A of the winow is the window hole plus the trimming. Try reducing it in the script.
In the object's 2D view, i removed the trimmings (no need for them there). And the WALLHOLE command made the 3D cut perfect. But in the plan view, the hole in the wall is still too big (makes room for the trimmings).
2003-12-17 01:26 PM
2003-12-17 07:45 PM
Thomas wrote:Open the script editor. Press the "details..." button.
Is there a simple way to fix this?
