‎2007-03-08 09:57 PM
‎2007-03-09 09:16 AM
tigr wrote:Short of finding a handy Autocad lying around, I really don't know ...
I need to import 3d DWG models into ArchiCAD, or better convert them into 3ds format so I can use the plug-in and keep materials. Those are not so complicated bathroom accessories and I tried File->Open Object->DWG but it does not preserve 3d data (no 3d object is created). Also importing it into SketchUp does not work properly - objects loose some faces. I looked for some DWG-3DS converter but with no luck, so I would be VERY GRATEFUL if someone can point me to the right converter, right conersion settings or even better, save those files as a 3ds. I'm running very low on time and are rather desperate. Thanks in advance.
‎2007-03-09 01:14 PM
‎2007-03-09 03:44 PM
‎2007-03-09 07:55 PM
‎2007-03-10 02:51 PM
‎2007-03-10 06:05 PM
There is one more glitch I found - when dwg is imported, it preserves the original geometry ot objects, while if 3ds is imported, AC smooths everything, even the most sharp edges!Did you use 3ds import plug-in ?, there is "force smooth" option be unchecked. If you do and it still does than fine, it is actually smooth object after all.
‎2007-03-11 04:45 PM
‎2007-03-11 05:14 PM
