Warning! Cannot find some Library Parts or Internal Macros.
Gisele
How to fix this warning message?
What are Internal Macros?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
3 ACCEPTED SOLUTIONS
Lingwisyer
Guru
Your library manager does not report any missing objects? Internal macros would be Called objects, so objects used by other objects.
They are not actually missing objects in your project.
They are Favourites set to use missing objects.
You need to edit those Favourites so they look for the correct objects in your loaded libraries.
Or load the library that those objects are saved in.
I am not sure if it will give you more information about which library they are from.
Looking at the names it is obviously a 26 library, but it could be INT or USA or another language version.
Lingwisyer
Guru
Missing favourites should not be causing your archive error message...
4 REPLIES 4
Lingwisyer
Guru
My library has Missing Library Parts.
Not sure how to recover them.
Lingwisyer
Guru
