2024-10-11 07:44 PM - last edited on 2024-10-13 12:15 AM by Laszlo Nagy
Hi all! just starting to mess with Archicad.
My question is regarding placing a window:
I have a stone house which existing walls are 50cm and made of granite. I am trying to draw the existing situation, but having troubles placing the window on the narrower part of reveal. I messed around with settings, but cant seem to move the window to the right place.
I managed to design the reveal correctly, but missing pushing the window to the outter end of it.
Please see attached images.
Thanks
2024-10-14 03:40 AM
Check your Reveal Type. There is a seperate one for your outcome.
Ling.
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2024-10-14 05:32 PM
Hi Ling. Thank you for your answer.
I think you misunderstood because I didnt explain all the detais. On the right side of the 2nd picture is the exterior, not the interior. My reveal is correct, i just cant after that place the window on the position it is at the moment. Its a simple granite existing wall and the windows are located on the reveal and not behind the reveal.
Thanks,
Rui
2024-10-15 04:06 AM
If you need it the opposite way around, with the narrow section outside, you could use the last option?
