cannot get .gsm to load in library
Dave Brach
I downloaded an object ("womanstanding2.gsm"), then exported it to my local drive where my company library is.  But it will not show up in the "objects" folder in the archicad object tool, even though I have clicked "reload and apply" and also closed the file and reopened it.
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
Dave Brach
Thanks for your responses. I realized that when I downloaded the object it went into the embedded library, and that it would not show in the linked library until I deleted it in the embedded library. So now it shows up fine.
AC26 MBP OS Ventura
Strange!  Wonder if something is wrong with the object?  To check, try (1) just dragging the object from Finder into your model to verify if that works correctly and/or (2) open the object with the GDL editor to see if anything is reported to be wrong with it.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
DGSketcher
Legend
If it's a Graphisoft object then it may be linked to called function(s) / data that you don't have in your library. The name you have supplied doesn't appear in my AC26 UKI library, a global search or the AC27TP INT library.
Dave Brach
AC26 MBP OS Ventura
