flipping awning and fixed portions of window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-12-30
09:16 PM
‎2023-05-24
12:33 PM
Rubia Torres
wb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-13 05:51 AM
As far as I know the standard window library can do it for you (see attached image), other window types can be even more versatile if you try with the setting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-13 05:49 PM
thanks Giang
H
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-13 06:32 PM
H
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-14 02:31 AM
Have a check in the model view options mate!
There is (in the Aus version of the lib) a section called Options For GDL Objects.
In the bottom right corner just above the Cancel & OK buttons is
Line Orientations (in the Show Opening Lines in 3D projections)
Just check that isn't set to the Hinges option.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-14 02:50 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-14 04:21 AM
I completely misread that!!
Do you have the Variable Window 17 at all?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-01-14 02:28 PM
Try a search via the Window Settings, the Window 17 should show up.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-23 11:42 PM
Is there a way of doing this in Archicad 25?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-24 09:30 AM
Which library are you on? If you're on the INT, or one of the libraries based on it, you can do as in the first reply or go to the "Opening Type and Angle..." page in the object and set the lower sash to to operable and the top to fixed.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
