Read more
pdf export image
viragsollei
Hello there!
I have a small problem with the pdfs that i export.
I do the floorplan designs on worksheets, and i add images. Some don't have a background. I set the image's background transparent on the panel (comes up with ctrl+t) and it looks fine on the worksheet. Then i save it as a pdf, and the background is back being white. I used the same images before, and this didn't happen that time.
Which settings can I change.
Thanks in advence
A fellow ArchiCADer
1 REPLY 1
Sam_at_SDA
How do you publish the pdfs? Is it with the publisher set or is it File > Print.
I would recommend checking the printer settings to make sure that images are showing ok.
Sam
