2021-06-07
10:16 AM
2023-05-23
04:03 PM
Rubia Torres
Solved! Go to Solution.
2021-06-07 10:24 AM
2021-06-07 10:24 AM
2021-06-07 05:48 PM
2021-06-07 08:07 PM
2021-06-08 03:31 AM
2021-06-08 04:25 AM
2021-06-08 07:01 AM
2021-06-08 05:07 PM
2021-06-08 05:16 PM
Barry wrote:I have noticed it for a while... and don't know if its a bug or a feature, but if you save only Morph elements as a module, then you can freely 3d rotate it as if it was a single element. If you save it along with any other element (Wall, Slab, etc) then when you update the module, the rotation is canceled and it behaves a a "regular" module.
However they can only be rotated in the horizontal plane (around the z-axis).
2021-06-09 04:06 AM
However they can only be rotated in the horizontal plane (around the z-axis).![]()
