AC 24 "Serious Error" message with prompt to Repair
BurimDermaku
1 REPLY 1
So, what happens when you click the Repair button?  After that, what happens if you try to start a fresh project?  Does the error return when opening the original, problematic file?  If so, you'll need to contact your local technical support.
One of the forum moderators
