2023-12-21 11:27 PM - last edited on 2024-04-17 10:41 AM by Aruzhan Ilaikova
The 3DConnexion 3D mouse is not functioning properly with AC27. I have had no problems with with AC25 & 26. PLEASE FIX!
2023-12-22 12:15 AM
Can you describe the problem.
In my case it works fine.
2023-12-22 12:24 AM
I can not navigate properly in 3D. Cannot go towards the model or rotate around it. The model goes off screen and when I fit to window the model ends up being at a weird orientation. Like upside down or way above looking down. I notice that you are running windows version. I am on a mac so might be a platform difference.
2023-12-22 03:32 AM
Hi MS, did you get a chance to go to the 3DC user site and ask your question there ? I had a problem with my CAD mouse not working on Mac Monterey and I had to install a driver that I downloaded from there. They should be able to help you and please indicate your OS.
2023-12-22 04:55 AM
I sent 3DC tech support an email today… graphisoft is looking into it and told me to post here as well… I have no issues with ac 25 & 26, just 27. I have the latest 3DC macOS driver installed… fortunately I haven’t started working in 27 yet I just randomly opened it up today to look at some of the new features. This is exactly why I wait 4-6 months till I start using a new release! lol
2023-12-22 07:13 AM
I have the space mouse as well and they both work fine on my system with all versions from 24 up to 27. I haven’t upgraded to Sonoma just yet because of the many problems others have experienced. It’s a pain when your tools don’t work properly. I have noticed the space mouse gets too sensitive when the charge is low. Hopefully you will get it sorted soon.
2023-12-22 10:36 PM
Interesting discovery… I originally opened the out of the box project template in AC27 and is where I had the issue. I was making some videos of the issues to send to 3DC and it occurred to me to open a AC26 project in AC27 and see what happened. To my surprise the mouse functioned properly. I shared with Graphisoft as well and they sent the info to the developers. Likely won’t hear back till after the new year.
2024-03-21 02:51 PM - edited 2024-03-21 03:06 PM
AC27 is the Windows version,
Does the Space Mouse rotate left and right with respect to the z-axis?
I can't do it on 3d Windows and BIMX.
Is there any other solution?
2024-03-21 03:12 PM
Hi Matt,
I've got two of the 3DCONNEXION Space Mouse, one wired, the other wireless (with the 7-button programmable mouse as well). No problems with either setup on Archicad 27. Although, when I first connected the wireless one it worked for a moment, then got stumped (most movement was gone, and what was left was erratic), so I just went into macOS Settings and clicked the Use Defaults button at bottom-right. This sorted everything.
Have you tried that?
2024-03-21 03:15 PM
It's the Windows version
It works well with other 3D programs.
