AC11: Grouping/Ungrouping in Elevation Window
Craig Bagley
I thought this is doable. I can't get two grouped elements to Ungroup in an Elevation Window.
Reference Guide states under "Grouping Elements": "Grouping and ungrouping are available in all editable window types (Floor Plan, Section/Elevation/IE, Detail, Worksheet, Layout, GDL Object's 2D Symbol) but not in the 3D Window; you can only Suspend Groups there."
Oddly enough, I CAN Ungroup the same elements in my 3D window, that I've been trying unsuccessfully to Ungroup in the Elevation Window.
The Elevation Window in my case is a Manual-Rebuild Window (which I've rebuilt). The grouped elements are a wall and an object.
There are obvious workarounds, but am I missing something?
AC20 USA/Build 8005
15" MBP, 16 GB RAM
macOS 10.13.6
0 REPLIES 0
