AC11 Text Opaque Block display bug in Layout
Eduardo Rolon
If you create a text box with white text (pen 91) and a dark grey Opaque Block (pen 191) and place it on a Master Layout it will not show on the Layouts. But if you just do white text over a fill with the same settings it displays fine.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
and the result
AC27 US/INT -> AC08
another Moderator
Rod Jurich
ejrolon wrote:
and the result
Would probabley get you a point as a beta tester
Looks like you may have found another bug.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Eduardo Rolon
The problem is that I am not beta testing I'm just trying to work on a project and I keep finding these things
AC27 US/INT -> AC08
another Moderator
