AC14 "Without Finishes" + Composite slab weirdness
fuzzytnth3
"Without Finishes" setting is behaving weirdly as I will explain...
In the image below the dialogue box displays the composite settings for the floor slab 175mm below FFL of Level +2. As you can see in the Section window when the slab is being cut in section the slab is displayed as being 50mm thick, when it should be 175mm thick as shown in the composite dialogue.
Weird enough you would think but look at the slab when it is displayed in elevation it is displayed at the correct depth!
Now this Composite slab and a couple of others are misbehaving like this when using the "Without Finishes" setting and the only common factor I can think of is that they all previously had more skins to represent suspended ceilings which have been deleted.
Anyone else seen this mad kind of behaviour?
Using AC25 5005 UKI FULL
1 REPLY 1
I haven't tested this yet, but I know there are several weird things happening when you use the without finishes / core only setting regarding slabs and roofs, that I don't think are resolved yet --
see http://archicad-talk.graphisoft.com/viewtopic.php?t=36098
Learn and get certified!
