AC15 - Very, very slow --- Fixed
I just started using AC15 (Win 7 64 bit, 12G RAM). I opened a project that was done in AC14 (64bit) and I find that AC15 takes an extremely long time to open the project and even longer to change the stories (> 20 mins)
There is a lot of disk activity and the memory usage hits 99%.
The same project is ok on AC14.
I have read a lots of posts on issues with AC15 but no one else appears to have this issue. What am I doing wrong?
13 REPLIES 13
That is interesting because by default that checkbox is not checked.
I even remember it being checked causing problems in previous versions.
Ok, so I ensured that this was unchecked and then activated the Navigator Preview palette. Same slow behavior and I had to terminate AC15.
That's good, so Support will appreciate that you nailed the exact problem.
Katalin Takacs
We appreciate and thank you for the investigation, solitaire.
This issue has been entered to our defect database.
Best regards,
Katalin Takacs
