I can confirm that the re-issued update for the broken update (KB3097877) is working fine.
The confusing part is the re-issue has exactly the same number as the broken one.
I manually un-installed the update (re-started) then checked for new updates and re-installed and restarted again.
I assume that given enough time the new update will automatically install if you have the updating set to automatic.
Lenovo Thinkpad -  i7-1270P   2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
