Advice needed
Daniels41
Hello I came back whit another small problem I encountered, I will add 2 picture and my question is how is it possible to make The A picture to look like the B picture. I mean how I can get that . Thanks in advance
In the first image, you either haven't modelled your floor slabs or you haven't turned their layer on.
The same in the second image, you either haven't modelled the site mesh or the layer is turned off.
Versions 6.5 to 26
How can I do that , can you please explain me the steps I need to do?  I mean how  I model my floor slabs and how i model the site mesh :). Thanks
Have a look at some of the training series on the Archicad YouTube channel.
There are many other videos there that will help you as well.
https://www.youtube.com/user/Archicad
It will be very difficult via this forum to explain everything you will need to do.
If you have access to anyone else with Archicad, maybe they will be kind enough to show you a few things.
You have managed to model the walls, doors, windows and roof.
I am sure you will be able to figure out the slab tool - just drawing a polygon in plan.
The mesh tool is a little more involved but do a little google searching and you will find plenty of videos on-line.
Versions 6.5 to 26
