Read more
ArchiCAD 16 Hotfix-1 (build 3014) released
Greg Kmethy
We have released Hotfix-1 (build 3014) for ArchiCAD 16. The primary reason for releasing this Hotfix is a crash that occurs fairly frequently when launching a second instance of ArchiCAD 16. Besides this, there are a couple of zone calculation-related fixes included.
The Hotfix is currently available through the automatic update system for INT, USA, AUS, NZE and GER language versions. Other language versions will be enabled as they pass QC. You can find a list of fixed bugs in the release note:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC16-3006to3014-ReleaseNotes.html
We are planning to release the next Hotfix early fall.
Gergely Kmethy
20 REPLIES 20
Balazs Simonyi
Graphisoft Alumni
Graphisoft Alumni
Sorry for the late answer.
Barry wrote:
There is a "set preferred language" button on the main page but this is next to the older downloads for 14 and 13 but as these were also INT it doesn't change anything.
If you select ArchiCAD 16 International version, there should be ArchiCAD 16 Australian version right under it. If it is not available, please send us a picture of your product page to this address: myarchicad at graphisoft dot com
Barry wrote:
Could INT be an option next to everyone's localised version?
International version is not sold in every country and the main problem that it is not supported. This is the reason why we have some restrictions on MyArchiCAD.
Best regards,
Balázs
