Archicad 27 MEP ungroup option
Jakob_Floyd
Hey,
In AC26 I used to draw cable carriers using MEP tool and if it automatically grouped all the separate elements. If I needed to make changes or delete a single element from the group, I would select the group and click ctrl+shift+G (shortcut for ungroup) and then I would be able to edit any element from that group.
In AC27 clicking ctrl+shift+G does nothing.
On the same note, how to change length of the already placed element? I must be blind, because I cannot find an option for that...
Thank you!
AC26
i9-12900 | 64GB RAM | 1TB NVME | RTX 3070 | WIN 11
Jakob_Floyd
I have spent more time on this and still have not found a solution.  Please, can someone tell me how to remove just a part of the cable tray run without redrawing the whole run? Just a reminder - this is on AC27.
AC26
It works - thank you! But jesus christ...
AC26
