Amanda wrote:
Also, if I do make a custom Zone Stamp, will it mess up the Interactive Schedule that I created for finishes based on the zones?
Maybe.
There is what appears to me to be an oversight in the design of the "Zone Stamp" subtype. The entire group of parameters titled "Listing Parameters" (and which all start with gs_list_) should IMHO be part of the subtype, but instead are hard-coded parameters in the couple of standard zone stamps that I just looked at.
What this means is that if you make your own stamp by saving a copy (or modifying a copy) of the stamp currently in use, you will get those parameters and your schedule will be fine.
If you think you'll be creating many custom zone stamps in your office, I would clean up the parameters and save a new subtype template (there is a check box for 'template' in the GDL editor window) ... and base new stamps on that template so that you would be sure to always use the same parameter set which would assure that sure your schedules would always come out correctly. [The new subtype, say "Finish Zone Stamp" would be a subtype of the GS "Zone Stamp", and so if GS adds new parameters to the "Zone Stamp" in the future, they would automatically appear in your objects.]
This is all slightly deep stuff for a firm new to ArchiCAD...so you might want to hire a consultant to help you. There are more than a few of us on this list ... but I think it would be best to find someone who can physically be in your office for this one. Your reseller?
HTH,
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
