2021-06-30
03:07 PM
2023-05-23
02:05 PM
Rubia Torres
Solved! Go to Solution.
2021-07-05 01:10 PM
2021-06-30 04:20 PM
Vojtech wrote:
Hi I have atypical roof construction and I would like to do bargeboard
1. White is from object
2. Blue is from beam - profile manager
3. Invisible Railing
4. Red is morph
Do you have some idea how to do it ? I tried all ways what i know but no of it is right
- object is not connecting
- beam profile also have wrong connection
- railing is have some issue to be show
- morph is curving with 3th angle what I don't want it
2021-06-30 06:52 PM
2021-07-01 12:31 AM
2021-07-01 03:37 AM
Vojtech wrote:If you are talking about the connections between segments, you can edit the rotation of each segment independently. You may then need to edit the connection type to get it to finish up cleanly. We did some experimenting back when the railing tool first came out which can be found here.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2021-07-01 09:35 AM
Ling.
2021-07-01 09:43 AM
Braza wrote:
Yes. This is a very very trick element to model.![]()
I think the correct name is "Roof Fascia" or "Fascia Board"
IMO the best (and probably the one) way to model this is with Morphs.
I would do this: Draw a flat Morph with your desired profile > Rotate it and place a copy on each node of the roof > Stretch each profile if necessary > Select all the flat profiles and make an "Union" > Draw Morph lines linking each profile node until it gets solid.
Hope this helps.
2021-07-01 09:50 AM
Kristian wrote:
We have a tool for Archicad that can do it:https://cadswift.com.au/products/Swift-Gutter-Plus.html
It is called "Swift Gutter Plus" and covers the 4 main elements of roof edges:
Fascia (bargeboard),
Gutter,
Downpipes, and
Soffit Lining.
We have spent some time on the "bargeboard" making sure that it joins correctly in all sorts of arrangements. One of our main clients is a builder of high end country homes who produces all trade packages directly from Archicad and even sends cutting list from Archicad to their factory. Therefore they required the bargeboard to mimic true life situations of custom homes for accurate cutting from their automated system.
If you have any questions please don't hesitate to ask.
2021-07-01 11:18 AM
2021-07-01 11:26 AM
Vojtech wrote:My bad. It seems that roof "vocabulary" is very complex, and actually has an element called Bargeboard.
Thanks I usually using word like : "vindskiva"(swedish) and google told me that is "Bargeboard" . Good to know
Vojtech wrote:I mean: You can model/draw individual profiles in key nodes and stretch them according to the desired outcome. Like this:
I don't understand how you mean union I have this joins
Can I rotate plane (photo 2) and continue with another direction/angel ?
