search
HelpSign In
  • Graphisoft Community (INT)
  • Re: [BUG] Duplicating design options with associat...
Options
  • Mark Topic as New
  • Mark Topic as Read
  • Pin this post for me
  • Subscribe to Topic
  • Mute
  • Printer Friendly Page
[BUG] Duplicating design options with associative dimension causes crash
thesleepofreason
thesleepofreason
Ace
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
  • Report Inappropriate Content
‎2023-10-30 05:59 PM - edited ‎2023-10-30 09:45 PM
Duplicating a design option containing an associative dimension but only one of its associated elements crashes AC after closing the manager, saving the changes.
1. Create an element in the main model.
2. Create a new option set and with the new option active create another element and an associative dimension between the element in the main model and the element in the design option.
3. Duplicate the design option through the manager and press OK.
4. Crash.
Running AC27 3001 INT on windows 10 and can be consistently reproduced in the default template.
WISHES | Dynamic Array/Sequence Tool | Element Visibility Control | Element Manager | New Approach to Change and Alternativ Designs | A more efficient Find & Select | Multiple Coordinate Systems| Automatic Name and ID for Folder Items | Criteria Expression Manager
Labels:
  • Labels:
  • Other
Reply
  • All forum topics
  • Previous Topic
  • Next Topic
11 REPLIES 11
thesleepofreason
thesleepofreason
Ace
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2023-11-04 09:08 PM - edited ‎2023-11-04 09:22 PM
Noticed that this post got moved from the wish forum to general discussion - for what reason? I obviously WISH for this to get fixed - not sure how it falls under "Posts about job ads, news about competitions, events, learning resources, research, etc.".
It goes without saying that it would fit perfectly in a BUG forum.
Reply
Mahmoud Qenawi
Mahmoud Qenawi
Ace
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2023-11-05 06:20 AM
Hi @thesleepofreason,
I tried to reproduce this situation any way but really it works fine for me & i don't see it's a bug.
So it may be something related to the operating system you have as your signature doesn't show this properly, thx.
AC 28 INT 3110/WIN 11
Reply
thesleepofreason
thesleepofreason
Ace
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2023-11-05 09:40 AM
The operating system is windows 10, as stated in the first post.
Link to a video reproducing the crash:
https://streamable.com/ajv5fq
Reply
Mahmoud Qenawi
Mahmoud Qenawi
Ace
In response to thesleepofreason
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2023-11-05 09:51 AM
Yes you're right it's win 10, sorry if didn't notice as i always look into the signature,
About the crash also yes that's happening for your Archicad but i tried again the same steps and fortunately no crash.
I'm so sorry about that & i hope the local support can help you fast.
Reply
DVH
DVH
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2024-02-19 07:12 PM
My AC 27 Crashed  today 2 times when saving a new duplicated Design Option.  Same exact procedure as "Thesleepofreason" noted here, and I'm on a MacBook Pro M3 Max running MacOS 14.3, with ArchiCAD 27 build 3001.
After deleting the associative dimensions... I re-tested and no Crash.... but I would like to keep the dimensions?
Is there a Bug Crash Fix for this... It has been nearly 4 months and I did not see any mention of Bug Crash Fix in AC 27 build 4060 release notes.
Dwayne Van Horn - Architect & AC User Since 1994
AC_27 MacBook Pro M3 Max, OSX 14.3
Levin Brown Architects, 2016- Present
Reply
In response to DVH
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2024-02-20 01:40 AM
Update 27.2.0 preview was released a couple of weeks ago ... https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-27-2-0-Update-Preview-release/ba-p/...
If is suitable for your language, you could give that a try.
Reply
Kelly at Kanvi Homes
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2024-03-01 05:37 PM
I've crashed 4 times in the last week while trying to add associated dimensions with multiple design options visible. Have submitted bug reports and will follow up with our local reseller. Will try the preview update, hope it helps!
Graphisoft Certified BIM Manager
AC27 USA - build 6000 - HP ZBook 15 G6 - Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM - Windows 10 Pro
Reply
jl_lt
jl_lt
Ace
In response to Kelly at Kanvi Homes
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2024-03-01 10:08 PM - edited ‎2024-03-01 10:13 PM
Hi! with the revamped dimension tool we have been proposing (that is, no "associative vs non associative" dimensions nonsense), none of this would be happening and would be having friday drinks already.
(Still, im sorry to hear about the problem @thesleepofreason )
Good friday to all
https://www.grupogennova.com/
Reply
Options
  • Mark as New
  • Subscribe
  • Mute
  • Permalink
  • Print
‎2024-03-02 12:16 AM
What build are you on, Kelly?  Your signature says 4060.  The Preview update that Barry mentions is build 5001.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Reply
  • « Previous
    • 1
    • 2
  • Next »
  • « Previous
    • 1
    • 2
  • Next »
Get notified about new replies
Subscribe to topic
Related articles
  • Reporting Assemblies (composites schedules) in Project data & BIM
  • Level Dimension hidden but still selectable on plan? in Documentation
  • Views and annotation in Documentation
  • [BUG] Duplicating design options with associative dimension causes crash in Modeling
  • Dimensioning Rails & Stairs in Documentation
Create new topic
Forum
Knowledge Base
Building Together
  • Graphisoft Insiders
  • Graphisoft Podcast
  • Product Roadmap
Developer Hub
Forum
Knowledge Base
Building Together
  • Product Roadmap
Developer Hub
Copyright © 2025 Graphisoft. All rights reserved.
