Break morph union
Can a union of morph elements be broken afterwards?
If yes, how is it done?
Thank you!
No, because the geometry of the Morph is modified and the two or more unified Morph elements will become a single Morph element.
If you cannot do it with the Undo command, then you will not be able to undo it later either.
1 REPLY 1
