Break morph union
Can a union of morph elements be broken afterwards?
If yes, how is it done?
Thank you!
1 REPLY 1
No, because the geometry of the Morph is modified and the two or more unified Morph elements will become a single Morph element.
If you cannot do it with the Undo command, then you will not be undo it later either.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC26
Loving Archicad since 1995
