2019-05-15
		06:02 PM
		2023-05-24
		07:22 PM
			Rubia Torres
Solved! Go to Solution.
2019-05-18 01:33 AM - edited 2024-01-13 02:01 AM
No, because the geometry of the Morph is modified and the two or more unified Morph elements will become a single Morph element.
If you cannot do it with the Undo command, then you will not be able to undo it later either.
