Read more
Can window trim show in curved wall?
Can Window trim show in curved wall? It seems to not show up curved or not.
4 REPLIES 4
It depends on the library part; whether it was written to do this or not.
Thanks Matthew,
Also I am having problems with the Wall accessories where I put the base, chair and crown moulding through the extra's menu. The panels cover up the transom on the door. I don't usually do much classic design but need to on this one.
You may do best to use library parts. I think Niel McCann's D3 Trims can do curves. I'm not sure about his door & window casings.
The add-on that creates trims, chair rails, base, etc. must have an error for curved wall. (see image) I guess I'll have build it from library parts or profiler. Thanks again.
