SOLVED!
Change Fills icon inside other commands
goncalovalente
Fills are available for 3 options: drafting fill, cover fill and cut fill.
I suggest that each of those icons should be the same as the ones related inside commands: Building Materials (image 1) and inside Attribute Manager/Surfaces (image 2) and Attribute Manager/Composites (image 3).
Images in attach showing the actual situation (with X mark) and the wishe situation (✓)
Thanks,
1 ACCEPTED SOLUTION
Solution
I will forward this information to GRAPHISOFT HQ for their consideration.
I do not think this belongs to the Wishes category though, so I moved it to a more proper section of the forum.
1 REPLY 1
Solution
