Change HLM Master ID in schedule
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-06-07 10:04 AM
2020-06-07
10:04 AM
I have tríed all i know, without succes.
Are there any way to change HLM Master Id IN Schedule? If not, it is a wish list
Thanks so much.
Joaquín
Archicad 25 SPA v6000
i9 14900K/32 Gb DDR4/1TB SSD/10GBPS Lan/Windows 11 PRO
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-06-07 10:31 AM
2020-06-07
10:31 AM
cagarruta wrote:Hello cagarruta,
What does it"HLM Master Id" means ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-06-07 01:18 PM
2020-06-07
01:18 PM
The Master ID of Hotlinked Modules. It is an ID you can specify when you place a Hotlinked Module, or later when you select the Hotlinked Module and go to its Settings Dialog.
It can help differentiate the IDs of elements located in Hotlinked Modules from the IDs of elements located in your main Project File into which the Hotlinked Module is placed.
In Labels and Schedules, you can display the "Hotlink and Element ID", in which case the Element ID of elements located within the Hotlinked Module will be prefixed by the Hotlinked Module's Master ID.
