Change all windows to simple openings...and keep the size.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-02-24 12:52 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-24 02:42 PM
Better use composite wall, unless the brick is separated for the renovation purposes.
The openings are best to be converted to empty one by one. Or, JUST select them and change to empty. Any parameter transfer will transfer the size, unless you switch it off...
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-24 03:46 PM
The brick is separated for scheduling (5D-project). I can't convert them one by one...I tried selecting them and change directly in the infor box but no matter how I do it the openings all get the same size. Maybe I need to open object settings and inject with a transfer option. Will try later.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-24 04:15 PM - edited 2022-02-24 04:16 PM
First, select all windows and then choose this option
Then select all doors and then do the same for them as well.
Archicad will create an empty opening the same size as the door/window.
It will not work if you select doors AND windows at the same time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-24 05:23 PM - edited 2022-02-24 05:23 PM
Nope https://youtu.be/eCjayp0EMuU
I have a faint memory this worked for me like ten years ago ...or so...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-27 07:04 AM
How to maintain the original windows size, when using this "use an empty opening"? All the selected windows were replaced with the same size opening.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-27 03:54 PM
This is the Japanese version, so sorry if it's a little different.
If you add Emptyopening to your favorites and uncheck the window size in the element transfer settings, the size will not change.
▼ウィッシュリスト(投票が集まるとGSの検討対象になります。賛同してくださる方は投票をお願いします!)
「仕上げツール」を本体機能に | 「メッシュから屋根を作成」を本体機能に | フロアレベルからメッシュ点高度 | 躯体以外を表示 | メッシュ頂点に一括ラベル | 断面形状パラメータパレット | STB取込みで梁端部を柱面 | RFAをパラメトリック | レイヤーセットを現在の設定で更新 | ひとつひとつの線の線種/色/表示非表示を変更できる機能(ラインワーク) | 「線として表示」としてもBIMx上で通り芯を表示 | 部材の始点/終点座標を一覧表とプロパティで取得 | 通り芯と要素の連動 | 表現の上書きに数式
Win10 / 13th Gen Corei7 / 32GB RAM / RTX2000Ada Laptop
AC17 - 27 / ACUG
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-27 05:44 PM
It is ok now! Thank you! ありがとう!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-28 12:55 AM
You can select all windows/doors & "Create openings". Maybe you change reveal in this time for intersection to brick wall.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-02-28 01:28 AM - edited 2022-02-28 01:29 AM
So that is the trick!
Create a favourite for an empty opening.
Create a transfer setting that does not include window size.
Select all of the windows you want as empty opening, right click on the 'Empty Opening' favourite and choose 'Apply transfer setting', and use the 'No size' transfer setting.
As Mats said, I am pretty sure you could just select all windows and change to empty openings before, but that must have been in the days before we had element transfer settings.
Thanks.
