Construct Boundary/ Prop Lines based on bearings/ distance
Would love to know how to construct property/ boundary lines based on the legal description bearings.. ie. N87 deg 37 min W 123.10'........
Temporarily change your Working Units (Preferences) to "surveyor's unit" as in screenshot...
Note that you also have a Dimension preference that can be set to surveyor units also if you need to have them show up in dims.
One of the forum moderators
With your preference changed, the Tracker will show / accept Surveyor units. Note that you do not have to type any punctuation (degree / minute / second marks).
Karl;
Thanks!!!!
