Control zone stamp rotation point
PVBergkrantz
Hello. I'm working with zone stamps in different modules hotlinked to one file for layouts, and would like that some of the zones always rotate to be 0 deg, which is easily achieved by ticking the "fixed" checkbox in the zone settings. However the rotation is not around the text itself, rather around some point on the zone. In some cases I have moved the zone stamp to the side of the zone, and would like it to remain there but rotate around its own axis, so as to not change position but just rotation. Is this possible?
See attached screenshots.
| AC 25 Int | Win10 | i7-7800X | 32 GB | GeForce RTX 2060 6GB |
PVBergkrantz
I found out this is because someone had moved the stamp using the "Move node" instead of "Move sub-element". The latter moves the anchor for both rotating and scaling in different scales.
PVBergkrantz
Thanks for posting back with the solution.
