2023-11-21
02:09 AM
2025-01-02
03:33 PM
Molinda Prey
Hi there, I need to place a window that involves two intersecting faces. Currently, I can only position two separate windows without combining them into a single unit. The problem I'm facing is that the intersection doesn't appear accurately in the plan view. Do you have any suggestions on how I could achieve this correctly? Thanks
Solved! Go to Solution.
2023-11-21 04:18 AM
Doors do not have this issue which has been a long term wish so if you have those situations, you are stuck with a scuffed corner...
2023-11-21 02:36 AM
They will never be a single unit.
In the window options you should see a section for corner connections.
2023-11-21 03:48 AM
Okay, Thanks
2023-11-21 04:18 AM
2023-11-21 06:41 AM
Thanks a lot .It is very helpful.
