Curtain Wall Scheme Display
Hello all,
has anyone seen this before? In one file, regardless of the settings, all curtain walls have a complex 3D scheme. When I copy these walls to other files, I do not see this same problem. Could this be some sort of graphic setting? Sorry if the awnser is obvious, I am relativly new to ArchiCAD.
Best
Is the model very far from the project origin?
Hi Barry,
Sorry, I did not see your response. The file was very far from origin, but we have since moved it to origin. unfortunatly the problem presists.
Could there still be something in the model that is very far from the origin?
If you start a new file and place a curtain wall (near the origin) does the same thing happen?
If it is OK, try copying & pasting the original curtain wall into the new file.
